Another Ported Design Recommendation?
Aeisuhr
Edit: decided to just go ported. Can anyone recommend the best ported box with these as external box dimensions, 20 D X 30 H X 38 W. just want the loudest possible in a 32-36 hz area. want to keep the 20x38 the same for outside specs if its just TOO big then lower the height as needed. This is from base to roof, so if it goes down at least i can see a little out the rear view lmao.
two Alpine SWR-12D4 Type-R 12's on roughly 1300rms @4ohm. had to scrap the old idea, this is for my daily mustang other than my wall build but will still be removing the backseats to mount this down. I believe alpine reccomends 1.5ish per sub but iv seen good things from people that said 2+ works well with these. Anything is helpfull thank you.
  • Who's Online   1 Member, 0 Anonymous, 1597 Guests (See full list)
