CodyLucente Posted September 7, 2016 Report Posted September 7, 2016 I recently bought 2 Orion subs and they have a different RMS, Nominal, Peak values of 600,1200,2400 respectively. prior to this i assumed that RMS and Nominal were the same. So then what is the Nominal rating and can i play on this consistantly? Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
Vice03 Posted September 7, 2016 Report Posted September 7, 2016 Marketing words mostly. RMS is going to be at least somewhat (outlier brands excluded) realistic when trying to match between subwoofers and amplifiers. I guess if you were buying a matching Orion amp you could use their Nominal rating (whatever they feel that means). Stick with RMS.
CodyLucente Posted September 7, 2016 Author Report Posted September 7, 2016 was going to go with a matched amp, but i found a used kicker DX 1000.1 amp that i think will match this nicely. i was asking because of my CTSounds 1200.1 that i can get to go own to 2400RMS at 0.5 Ohms Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
