Need help with subwoofer enclosure ground zero audio
Marty Collins
I just got 4 ground zero 18s gzhwx18 spl and 2 4k amps. I want to build a daily pounder. The manual has ported and 4th order specs. But I've learned to sometimes it's better to not use the specs offered. I was thinking going with ported as I'm able to make it more aesthetically pleasing lol
Product name GZHW 18XSPL-D1
Product type Subwoofer chassis
Diameter 464 mm / 18.27
Mounting diameter 425 mm / 16.73
Mounting depth 255 mm / 10.04
Magnet dimension 3 x 220x 20 mm
Voice coil diameter 75 mm / 3 Round Wire
Voice coil winding height 45 mm / 1.77
Top plate height 13 mm / 0.51
Linear excursion (one direction) 16 mm / 0.63
Effective Xmax 45 mm / 1.77
Power handling 4000 W SPL Power
Impedance 2 x 1 Ohm
Re 1.75 Ohm
Res 28.3 Ohm
FS 34.3 Hz
Qms 6.553
Qes 0.404
Qts 0.381
Rms 19.982 kg/s
Cms 0.035 mm/N
Mms 606.79 gr
BL 23.778 N/A
SPL (1w/1m) 92 dB
VAS 75.21 L / 2.66 cu.ft
Le 2.37 mH
Recommended freq. response 35 100 Hz
Recommended amplifier power 2000 4000 WRMS @2Ohm (0,5 Ohm)
Thanks
  • Who's Online   0 Members, 0 Anonymous, 4815 Guests (See full list)
