Need help with box design for 2 HDC3 12's Joe X
Joe X, I need a little help, this will be my first system in over 20 years that I have installed, as I am getting a little back into car audio.  I have been playing with Torres, but would like to have your advice and a 3D image with a cut sheet list if possible.  You posted a nice design for SNYPER recently, and I had planned on something similar, except I would like the speakers and port to face up.
I have 2 new Soundqubed HDC3 D1 12's that I am building a box for my Ford Ranger. I have a new Soundqubed 7k to power them.    I realize that after impedance rise and voltage drop, probably more like 2k watts per sub at the most.  I have read that between net 2.25 and 2.5 cubes is optimal.  I think I would like it tuned between 32-35hz or whatever is best.  Again, I would like the subs and port facing up, and I think having the slot port in the middle would be best and also help with the bracing, but am open to having it at either the drivers or passengers side if it is louder. The amp will be mounted on the box as I have no other place to mount it, so bracing is important.  Also what would be a good frequency to set the subsonic filter?  This is just a daily driver.
Thank you for all of your help and tips.
 These are the dimensions I have to work with and are probably very close to what is ideal, the Width and Depth are fixed and need to stay with the measurement listed.
External:
Width = 51" - Fixed measurement
Height = 20" -  soft maximum to keep under rear glass window line, lower the better.
Depth = 14" - Fixed measurement
Speakers parameters:
Model
HDC3.112
Woofer Size
12"
F(s)
43 Hz
R(e)
Z(max)
Q(ms)
7.313
Q(es)
0.305
Q(ts)
0.375
V(as)
20.33 liters (0.717^ft)
L(e)
mH
n(0)
M(ms)
grams
C(ms)
mm/N
Sensitivity 1W/1m
88.172db 1W/1m
BL
Xmax (Peak to Peak)
36mm
Magnet Weight
300oz
Coil Diameter
3.0"
Coil Length
54.229mm
Usable Throw
68mm
RMS Power
1500W
Peak Power
4500W
Displacement
0.13^ft
Mounting Depth
8"
Circle Cutout
11.25"
Outer Diameter W/Gasket
12.875"
  • Who's Online   0 Members, 0 Anonymous, 3729 Guests (See full list)
