Mr.Angel Posted March 5, 2019 Report Posted March 5, 2019 (edited) Car: BMW 3 series 2 mono Amps: alpine mrv500, 2 subwoofers Problem: Theres no volume display on the headunit, How do I properly set my gains without knowing the volume level it distorts at? explain in details please. Question #2, I Listen to music on the Aux cord so do I need to play the DD-1 playlist off my phone rather than the Cd? Edited March 5, 2019 by Mr.Angel Quote
Mr.Angel Posted March 5, 2019 Author Report Posted March 5, 2019 8 minutes ago, Pelihagen said: What headunit do you have? Factory headunit with the idrive (navigation screen) Quote
Pelihagen Posted March 5, 2019 Report Posted March 5, 2019 2 minutes ago, Mr.Angel said: Factory headunit with the idrive (navigation screen) Ahh I see. I don't know anything about stock headunits really. But I have a DD-1 my self, and to your second question; In my experience at least (aftermarket Pioneer headunit) the volume levels are different between AUX and Bluetooth for example (by a lot actually). I don't know why that is though. Quote
Mr.Angel Posted March 5, 2019 Author Report Posted March 5, 2019 11 minutes ago, Pelihagen said: Ahh I see. I don't know anything about stock headunits really. But I have a DD-1 my self, and to your second question; In my experience at least (aftermarket Pioneer headunit) the volume levels are different between AUX and Bluetooth for example (by a lot actually). I don't know why that is though. It's just a bit difficult to use it,. For one, factory speakers so it plays the tracks and the sound is annoying when I try to find where it distorts at. the only thing connect to the amp is just the sub wires along with Rca for the line out converter Quote
Pelihagen Posted March 5, 2019 Report Posted March 5, 2019 3 minutes ago, Mr.Angel said: It's just a bit difficult to use it,. For one, factory speakers so it plays the tracks and the sound is annoying when I try to find where it distorts at. the only thing connect to the amp is just the sub wires along with Rca for the line out converter Yeah 😕 Hopefully someone with more knowledge can chime in and help you out. Good luck. 🙂 Quote
Mr.Angel Posted March 5, 2019 Author Report Posted March 5, 2019 3 minutes ago, Pelihagen said: Yeah " src="https://cdn.jsdelivr.net/emojione/assets/3.1/png/64/1f615.png"> Hopefully someone with more knowledge can chime in and help you out. Good luck. " src="https://cdn.jsdelivr.net/emojione/assets/3.1/png/64/1f642.png"> btw when tuning, do you set your bass boost on the amp all the way up (or preference) or leave evrything flat ? Quote
Pelihagen Posted March 5, 2019 Report Posted March 5, 2019 (edited) 3 minutes ago, Mr.Angel said: btw when tuning, do you set your bass boost on the amp all the way up (or preference) or leave evrything flat ? I don't use bass boost on my amplifiers, but I have a remote bass-knob which I turn all the way up, then tune it. It says clearer how you can do it in the manual Edit: I also have everything else flat, on my headunit for example. Edited March 5, 2019 by Pelihagen Quote
Mr.Angel Posted March 5, 2019 Author Report Posted March 5, 2019 27 minutes ago, Pelihagen said: I don't use bass boost on my amplifiers, but I have a remote bass-knob which I turn all the way up, then tune it. It says clearer how you can do it in the manual Edit: I also have everything else flat, on my headunit for example. thing is I have 2 mono amps so I would need 2 bass boost knobs sadly Quote
Pelihagen Posted March 5, 2019 Report Posted March 5, 2019 9 minutes ago, Mr.Angel said: thing is I have 2 mono amps so I would need 2 bass boost knobs sadly I have two amps as well, but I have them in a strapped configuration, which allows me to control them with just 1 knob. Quote
