Help with Box design for Adire 15” Tumult sub
Bus Box
Hi Guys
I need some help with designing a box for my new Adire Audio 15” Tumult, this will be my 1st box build so a total noob to this. Would like to go ported and tuned to between 33-35 Hz but not sure if I have enough space for this. Open  to slot port or aero. If I don’t have enough space I will run it sealed. Will be a daily set up, playing rap and EDM music.
Box needs to be a wedge shape, exterior dimensions 20” High, 42.5” wide, base depth 14” and top depth 11”. Will be using 3/4” MDF with double baffle.
Will be run 4 ohm and powered by Mosconi AS300.2 bridged to run 1100 RMS. Lithium Ion battery and 0awg cable + Big 3 all done. Will be in an SUV behind 3rd row seats.
speaker specs
Dual 2ohm coils
Fs 19.08 hz. Re 3.66ohm. Qms 3.84 Qes.428 Qts .428 Le 3.81mh (1.905 per coil). Mms 352.72g Cms.20 mm/N. Sd 807.64 cm^2. Vas 185.32 L. Spl 86.01db @ 1w/1m. BL 17.7 Xmax 34mm one way. Rms 1000w on program 1500 thermal. Displacement is .17 cu ft.
Thanks in advance for any assistance you can offer.
  • Who's Online   0 Members, 0 Anonymous, 3755 Guests (See full list)
