Stereo Integrity HST-15 ported box build
Surfer J
Sorry again there is not much of an update today. Okay nothing happened with my box today. I was not in the shop so I was unable to work on by build. Yea I keep noticing little things I could have or should have done. Yes my next box will be much improved in many little ways.
"A nod is just as good as a wink to a blind horse." Rolf - Ed, Edd, and Eddy
Hey, you can always make changes... even if you have to take 1 side of the box off and sand or router.  I'm building my 2nd under seat box, and cramming everything I need into my space is a nightmare, so I'm taking my sweet time and making sure it's all perfect before I glue everything together
05 TL build log SOLD
Today I was finally able to work on my box. I got the last side glued on. I will be able to finish it up tomorrow.
Here it is with glue on all edges.
The outside port wall was about 1/16" short. I used liquid nails caulk to fill the gap as I glued it up. Also the last side wasn't as square as I thought is was.
I will have to to some pretty heavy sanding on a few of the edges. Luckily we have belt sanders at work. That should help to make much quicker work of what sanding I need to do.
Well this morning didn't go as planned. I got in my truck to go to work aaaannnndddddddd....... no good. It was running really rough, like it was missing a cylinder. It turned out I had a spark plug go bad. Easy fix, but costly in time. So no work was done on the box today. Bummed. I hope to complete on Monday.
Today I as able to glue the final baffle piece to the top of the box.
For some reason I can't up load any pics. I  keep getting a message that the photos are too large., even though I am using the same size I used for all the other ones. I will try to post them again later.
  • 1 month later...
