Guest MegaloManiac
thank you  MEgalo Maniac. i just put those subs on order and the amp well still searching but thanks for the help.
what kinda coils did you get? i think you more than likely need dual4
Guest MegaloManiac
i got the dual 4 coils and yea the free shippin is nice. im excited for these subs to show up. :D
wow that was the fastest sale ever. I can promise you wont regret.
You best post pics  ;D
also since they are dual 4, you will be able to wire them in 2ohms(paralel) or 8ohms(series), each sub can handle 800 watts rms. so make sure your amp can do atleast 600watts x 2 at 2ohms
i have to disagree with this. if you wire 2 dual 4 ohm voice coils in parallel it gives you a 1 ohm load. if you wire them in series it will give you a 4 ohm load. now if you plan to run an amp to each sub you can do 2 ohms or 8 ohms.
18's in a wall to come....Its not all about the posts....check the member #...
Guest MegaloManiac
each sub not wiring them together, so i guess he could easily just pic any ohm load he'd like, but more than likely most amps he'll be wiring them in 2ohms each
Damn. how much simplier can that get. thats like great visuals. it makes sense. now i guess it time to build. Thank you guys. if there are any additionall tips/advice feel free to tell me
