No.
Class D is PWM technology, that is Pulse Width Modulation. In other words, 'digital.' Class H topology is a multi stepped transformer/power stage. So at low power levels, the power stage is fed from a lower winding, higher power uses a higher winding on the transformer.
Class D is not very good at reproducing high frequencies as that involves having the oscillator set to a much, much higer frequency, often beyond its limits. It also sounds 'clinical' and adds a sense of distortion to the overall tone. Class H is effecient and powerful, yet is still heavy, bulky and has its power limitations.
In short, Class D is good for low frequency applications where high end fidelity is not needed but a metric dickton of power is. Class H is common in many Pro Audio amps as it can drive almost anything you put on it, and do it well. And no, Class H is not improved class D. Lab.Gruppen's class TD and RF's BD is though. I still reccommend grabbing a TAPCO and throwing that on, one coil a side. Parallel the amplifier so that both sides of the amp recieve the same input, put both attentuators wide open and prepare for take-off.
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
