Gbaker Posted June 23, 2021 Report Posted June 23, 2021 Just wandering about the power output of this amp? Rms power that is.Also wondering about build quality.
johnkmatthew90 Posted June 24, 2021 Report Posted June 24, 2021 RMS power @ 4 Ohms: 250 Watts x 4. Max power @ 2 Ohms: 500 Watts x 4. American Bass is well-known for the quality of its speakers, but it also makes outstanding components that are easy to mount. The weight of the mount is less than 12 lbs, which means you can use a smaller mounting plane. This means that you do not have to bolt down a 3/4-inch thick sheet of plywood across the width of your trunk space. Rather, it should be set off to one side and used with an even thinner sheet.
