Digital Design 710 F
I’m new to forums ,but here I go . I have a 2015 Ford F150 supercrew with the 2.5 LMI Welding seat lift .I just purchased 2 DD710 F the latest revision, I have around 3.3 gross cuft  minus woofer and port displacement . Im trying to tune port around 32hz how do I found out how big and long  the slot port needs to be …why maintaining correct airspace …Yalls help is really needed. Thanks in advance
Welcome to me and you also.
To calculate the slot port dimensions for your DD710 F subwoofers in the 3.3 cuft enclosure aiming for a 32Hz tune, you can use a reliable online port calculator. Input your box volume, tuning frequency, and the number of ports. This will provide you with the slot port's dimensions (width, height, and length) for optimal performance while maintaining the correct airspace.
Good luck with your setup!
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
