need help on making a box for my subwoofers
siikdude
hi there..  so i have 4 x skar zvxv2 d2 subs and i have a jeep wrangler 10' the max diamentions in m jeep is a width 42in  x length 26 1/2in  would like less like 23  length or less if possible to have some space in my jeep, and the height i can do  max 17in or i can do a  Wedge Enclosures that measures 18 1/2in  length max by 42 width max by back height max 25in and front height max 17in.  i have some some models of what i was thinking. but i believe it has to much volume in it ill post it btw i like to listen to trap, rap, dubstep, house music, hiphop, edm
drivers recommendation is as followed by skar audio
Recommended Enclosure Specifications
Recommended Port Area 38.0 in² ,
 Recommended Ported Volume 3.00 ft³
,Sealed Volume Not Recommended
Recommended Tuning Frequency 34 Hz
Subwoofer Measurements
Total Height 11.39"
Mounting Depth 9.89"
Magnet Diameter 7.85"
Cut-out Diameter 11.25"
  Outside Diameter 12.62"
T/S Parameters
Bl- 21.8 n/a,         Fs 44.0 Hz,         Re Dual 2 Ω,     Sd 510.0 cm2,          Cms 0.04 mm/N         ,Mms 341.0 gr,        Qes 0.50,        Qms 6.10,        Qts 0.45.           Vas 25.6 L.          Nref 0.15%.           Xmax 29 mm (one-way),            Sensitvity 83.7 dB
box max dementions
24 length x 42 width x 25 height back panel with front panel 17 height,  or 17 height max
volume displacement of my 4 subs should be 33.84 liters  im not 100% sure on this.
  this was my initial idea, and the middle has plexiglass.
pictures are in link below
https://discord.com/channels/@me/1126916059262373989/1189004902786150420
this is my other model.. thats 24.25 L x 31.5 x front 16.5h and back  24.5h
https://discord.com/channels/@me/1126916059262373989/1189320534475939880
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
