More Spl..
With 1 8" sub off 500w it was a little over 12dB for us _b
That's quite a lot louder :)
Your mileage may vary...
wow...i really need to get this box ported
1999 Chevy Blazer 4 dr.
L5 Kicker 15"
Kicker 750.1
4" long, are you sure about that tuning?
I would go 2 4" pipes at the least. You need a bit more port area for a 15" sub. Just make them as long as you can (leave like 4-5" at the back for the ports to 'breathe' and I'm sure you'll be happy with it. You can always pull them out and cut them shorter, just think about it carefully when you put them in ;)
Ya I`m pretty sure using his dimensions he gave on first page based on 3/4" mdf its 4.22 cu ft minus port and sub displacement, so 1 4" pipe 4" long tunes to 35hz based on 3.9 cu. ft net
So if you want 2 4" ports make them 11.25" long at it will tune to 35hz
Get porting :good:
Hope this helps
Get porting :good:
Hope this helps
yea im slowly learning...thanks
L5 Kicker 15"
Kicker 750.1
yea im slowly leaning...thanks
No Prob man, and if you dont mind spending a little bit of money on ports, you will gain a bit using flared round ports, you cna get from www.psp-inc.com
Hope this helps
Garett
Hope this helps
Garett
i have like 4 of them flared ports out of a audiobaun box but not sure if there big enough might only be 3"
L5 Kicker 15"
Kicker 750.1
If you measure the exact inside Dimension of the pipe part (not the flared end) I can calculate for there size for them if you want.
Let me know there inside diameter and length
Garett
4" long x 3" inside
I wouldn`t bother with the 3" ones, as to tune low for daily you could only use 2 which is only 14 sq. in. of port which is equivent to roughly 1 4" port.
Grab 2 pieces of 4" pvc pipe and make them 11.25" and enjoy your new found SPL
Garett
Garett
kool thanks man.. :good:
L5 Kicker 15"
Kicker 750.1
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
