00_XJ Posted July 7, 2008 Report Posted July 7, 2008 I'm new to this, like this is the second system I have installed new, and today I installed my amp. Cranked the truck up, nothing. So I checked all my wires and they were all hooked up correctly (I think), nothing was loose. Well I got the meter out and hooked it up to the amp ground and power terminals and it's reading 14.05. Please let me know what could be wrong, blown fuse? Something else? Am I not metering it right? Anything at all. Thanks. Quote 2000 Jeep Cherokee -DC Audio -Memphis -Audioque -SecondSkin -Pioneer -KnuKonceptz
Coolwazabi Posted July 7, 2008 Report Posted July 7, 2008 everything sounds to be correct... did you install the remote wire ? Quote
00_XJ Posted July 7, 2008 Author Report Posted July 7, 2008 everything sounds to be correct... did you install the remote wire ? Yep, and wouldn't the power light still come on even if it wasn't installed, it just wouldn't go off? Maybe I'm wrong. Quote 2000 Jeep Cherokee -DC Audio -Memphis -Audioque -SecondSkin -Pioneer -KnuKonceptz
jayjay6888 Posted July 7, 2008 Report Posted July 7, 2008 no the power light would turn on without the remote wire.... b/c if you turn you head unit off and then look back at your amp it will be off so double check your remote Quote 1 Fi Sp4 18 Crescendo 2k selenium mids audioque supertweets Hifonics for mids and and highs 1/0 power and grounds ---> on the way singer alt and possibly another 2k depending how sub likes 1 2k
Coolwazabi Posted July 7, 2008 Report Posted July 7, 2008 Yep, and wouldn't the power light still come on even if it wasn't installed, it just wouldn't go off? Maybe I'm wrong. honestly.. not sure.. never tried it w/o the remote... Quote
DUBIE Posted July 7, 2008 Report Posted July 7, 2008 no the power light would turn on without the remote wire.... b/c if you turn you head unit off and then look back at your amp it will be off so double check your remote i might be wrong but in my case 1 time i did that..i wired everything except for the remote and the amp wouldnt turn on or the light..until i wired the remote to the amp..the amp finally turned on...maybe the RCA's aint connected..did you double check??.. Quote
00_XJ Posted July 7, 2008 Author Report Posted July 7, 2008 i might be wrong but in my case 1 time i did that..i wired everything except for the remote and the amp wouldnt turn on or the light..until i wired the remote to the amp..the amp finally turned on...maybe the RCA's aint connected..did you double check??.. Yep double checked the remote wire, the RCA cables could be the problem because I wasn't sure which set on the amp to hook them to, ha I told you I was a noob Quote 2000 Jeep Cherokee -DC Audio -Memphis -Audioque -SecondSkin -Pioneer -KnuKonceptz
DUBIE Posted July 7, 2008 Report Posted July 7, 2008 Yep double checked the remote wire, the RCA cables could be the problem because I wasn't sure which set on the amp to hook them to, ha I told you I was a noob hahaha naw bro...everybody makes mistakes..its ku thoug..so were the RCA's your problem? Quote
00_XJ Posted July 7, 2008 Author Report Posted July 7, 2008 hahaha naw bro...everybody makes mistakes..its ku thoug..so were the RCA's your problem? well I'm not sure, ha I'll try a few different things and get back at ya Quote 2000 Jeep Cherokee -DC Audio -Memphis -Audioque -SecondSkin -Pioneer -KnuKonceptz
DUBIE Posted July 7, 2008 Report Posted July 7, 2008 well I'm not sure, ha I'll try a few different things and get back at ya o aight..and double check everything ... Quote
