2001JeepGrandCherokee Posted July 7, 2008 Report Posted July 7, 2008 I am going to be running two Bl 15's with about 1700 rms to each. Looking for a good box design to fit in the back of my jeep. Dimensions are: 41 Inchs wide 21 Inchs tall 31 Inches deep I am looking to display the amps on the back of the box, facing the hatch. Edit, these are maximums only. Can be anywhere in between.
BigPimpin91 Posted July 8, 2008 Report Posted July 8, 2008 Port can is the height of the box internally. If you want to display your amps I suggest porting out of the rear left or rear right of the back panel. BigPimpin91's Banging Music
2001JeepGrandCherokee Posted July 8, 2008 Author Report Posted July 8, 2008 Port can is the height of the box internally. If you want to display your amps I suggest porting out of the rear left or rear right of the back panel. Thanks for the help, I had to maginify it a lot to see it though..Small computer screen I guess it will blow up when i print it too.
