Hell use the Kinetik as the Starter batt if you can and use the yellow top as the auxillary if all of that will fit propperly.
IMO I would get the better batt as close to the alt as possible.
But I understand if the largest Kinetk won't fit. Then do it the way you were going to do it.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
