ok so ive had my system and everything wired for a few months or so now....well im on a trip and ive stopped multiple times shut my jeep off several times and its all been great, well i stopped about an hour ago at a hotel and when i shut it off, the cd player stayed on...this is the first time its happened and nothing else is on, when the H.U. stays on the amps are off and i dont know whats going on....if it helps its an Alpine 9881....anyone know?
J.A.M AUDIO
Owner
North Texas
Authorized DC Sound Lab Dealers
That is the wierdest problem I have ever heard of.
Are your amps hooked up to the remote wire on the H/U or ignition wire?
Is there any chance you have turn the ingnition too far back to just fire up the radio.
Did you turn the ignition back too far?
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Start the car up and turn it back off and see if it turns off.
Open the door and shut it see if it shuts off.
I'm no help with this one unless I'm there. Sorry man
amps are run through a relay actually so all of the remote on the back of H.U. and no ignition isnt too far back, i had the keys in my pocket...and thats why i have never heard of this
J.A.M AUDIO
Owner
North Texas
tried that bro....didnt work, thanks for all the help tho, greatly appreciated
J.A.M AUDIO
Owner
North Texas
Ya sorry man
with out being there IDK, that is the weirdest thing I have ever heard. It don't make sense.
Ya sorry man
i didnt think so either, but i wasnt sure....but thanks again!
J.A.M AUDIO
Owner
North Texas
so headunit still plays but sub amps not on there ran threw a relay ona switch i presume, maby ur acc wire came loose and went in contact with the 12v wire so its on all the time or switch is messed up, take the headunit out and see if anything came undone and if all else fails take off the faceplate so it will turn off and go from there might be ur only option unless somethin came loose behind the unit yellow is constant 12v, red is acc on the ignition, and black is ground, look and see if the yellow came in contact with any other wire is the only thing i can tell ya or somethin came loose in the headunit but if u want to turn it off just take off the faceplate and then try it when u get time take it out and hook some test leads with a light in it and see if anything other than yellow has constant 12v while car is off, hope this helps and good luck man wit ur prob
kool thanx man, like i said im in a hotel right now lol but ill be home tomorrow evening and ill check everything and ill let yall know, and again thanks for all the help guys.
J.A.M AUDIO
Owner
North Texas
np man thats what smd is for :friends:
  • Who's Online   0 Members, 0 Anonymous, 651 Guests (See full list)
