justbump'n Posted July 16, 2008 Report Posted July 16, 2008 Okay in my Nissan I have 2 RD Audio 15's with a Cadence 6000watt amp with 3 batteries my question is if i get my wifes s10 Chevy Blazer can I run 0gauge under the carpet in the cab or will I have to run it up the frame???Second question, My deck skips really bad when Im bassing really hard in the truck so my theory is when I put my deck in the wifes blazer will that help with the skipping????Steve if you are reading this could you chime in???? The reason that I ask is because of the Civic and the Tahoe It would kinda be the same as me going from a tiny nissan ext.cab to the blazer!!!!LOL What can I expect and what problems should I look for????Third,I dont know if I want to go with 4 10's or 4 12's or 4 15's I feel that if I go with the 15's that they may be starving for air!!!!! And Im still deciding if I want to keep the 6000watt amp or not! The only reason Im thinking that is because of the wiring I dont want to cut into the body like I have done with the truck so that i could run the wiring to the amp in tha bed!Any help will be appreciated thank you all.
01xtreme Posted July 16, 2008 Report Posted July 16, 2008 Okay in my Nissan I have 2 RD Audio 15's with a Cadence 6000watt amp with 3 batteries my question is if i get my wifes s10 Chevy Blazer can I run 0gauge under the carpet in the cab or will I have to run it up the frame???Second question, My deck skips really bad when Im bassing really hard in the truck so my theory is when I put my deck in the wifes blazer will that help with the skipping????Steve if you are reading this could you chime in???? The reason that I ask is because of the Civic and the Tahoe It would kinda be the same as me going from a tiny nissan ext.cab to the blazer!!!!LOL What can I expect and what problems should I look for????Third,I dont know if I want to go with 4 10's or 4 12's or 4 15's I feel that if I go with the 15's that they may be starving for air!!!!! And Im still deciding if I want to keep the 6000watt amp or not! The only reason Im thinking that is because of the wiring I dont want to cut into the body like I have done with the truck so that i could run the wiring to the amp in tha bed!Any help will be appreciated thank you all. Ok as far as running the 0 gauge under the carpet, that is exactly what I did. I ran it through thr antenna grommet right under the AC box on the passenger side of the fire wall. if you run it correctly you can not even tell it is there. As far as running the subs it all depends on what you are will to lose for you box to be big enough. I have a 2 door blazer and I fit a 6.5cf box behind the back seat including a 1.5cf port. If you are wanting to run a true 6000 watt amp you will need a bigger alternator, and probably a couple batteries or more. how big is the amp you plan on running? installing an amp seems to be the most time consuming part since space is so cramped behind the second row. My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon...
justbump'n Posted July 16, 2008 Author Report Posted July 16, 2008 Thanks for the info!!!!!! Now I will be using my 6000watt amp in the blazer!!!!! I have had tens and they sound great also had 12's and they sound awesome to now im kinda feeling that 15's may be to big for the blazer unless I just use the 2 i got but kinda want to do the multiple thing but man the 15's hit so hard right now!!!!!!!LOL
01xtreme Posted July 16, 2008 Report Posted July 16, 2008 If you can lose the back seat, or atleast have it folded down you should be fine for 4 15's. I fit 8cf below the windowline without back seats. My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon...
