ok iv got 6 jbl gti's ... im currently running 2 subs independantly on 2 amps, and the last 4 in my box are ran on 2 amps.. the ohm load is too low for recomendation but it has workd in the past...?
but neways my subs all play good but the last 2 on my passenger side make this awfull pop and like just terible noise??? ne one got ne idea?
i did have a power wire loose to my amp but i pulled on it yesterday and it seemed tight.... let me kno if you have ne idea as to what this may be
please help...
bout to get my last 2 amps in and will be running them all independantly but i need to kno if you think i got like a wireing problem or phase issues or ???
jus let me kno, if you got even a thought as to what it could be
thanks guys
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
oh and they all play fine at a decently loud volume but its like the difference between 1 notch and they will start doing it ... and i think they have done it when ill be rolling windows up and while its cranked sounds good then start to roll dwn my windows and itl do it ????
ne help guys
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
im actually having this problem with my sub, i think its not screwed in good enough maybe ???
are you talking to the box???
b/c it is only my back 2 subs out of all my subs???
i was thinking phase or a neg backwards??? sumthing like that ... but im not forsure how to check all that other than rip it all back out ??
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
That is mechanical failure or over excursion of the woofer
Keep doing it that sun will blow might be on its way out now that makes the woofer really weak
Why does it do it with windows down I have found windows up with no release of the persure the subs can take more power windows down you don't have that back persure so less power more excursion
Wait for your amps and do it right
but ur saying wait on my amps???
wont that be more power to the subs????
so have i reached my limit with my subs???
and the back passenger side 2 dnt move as much as th rest i got all the other woffers to move similar but i can get those to b/c they start doing that shit ???
im jus making sure what ur saying is correct in my sittuation
thanks man
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
and 1 more thing is that sumtimes when they do this they take a min to kick back in ?? this meaning????
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
Say good buy to them woffers naw that's prolly your amp clipping from the crazy ohm load that pop makes
The jbl's take like 500 watts man you need to get all the amps right. And back off the power those suns don't need a gang of power
alright man thanks for helping iv been wiggn out abt this...
but honestly iv been thinkn of just saying to hell with these jbls ...
id like to do some :
*FI-bl or btl's
*DC- lvl5
you think theyd wrk in the same box i think the fi would but didnt kno abt dc's??? but do you think that i should upgrade those ...
or should i say would some new/bigger /better subs make it louder .... b/c i was abt to try n build a clam for 8-15"??? but im not gona do it if i can get as loud as i want with 6 of other subs....
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
1 you need all matching amps
2 I dunno about your box so I can't say yes fi or DC will work in there
3 if you get all matching amps get a maxlink so you can have them all working the same
4 we have a team mate that blew threw like 20 jbl gti subs in comp there not for bangin hard there sq
5 so yes the fi or DC are perfect for what you wanna do I would ditch the jbl
