GEO FI, Hifonics BUILD
I asked teh guys at Sundown about that test.
1 amp, single 1000ca everstart maxx, factory alt
4 ohm nominal = 518 watts @ 88% efficiency (voltage fell from 14.3v, to 14.0v)
2 ohm nominal = 948 watts @ 85% efficiency (voltage fell from 14.3v, to 13.6v)
1 ohm nominal = 1510 watts @ 78% efficiency (voltage fell from 14.3v, to 12.4v)
.5 ohm nominal = 1615 watts @ 72% efficiency (voltage fell from 14.3v, to 11.8v)
.35 ohm nominal = 1748 watts @ 67% efficiency (voltage fell from 14.3v, to 11.4v)
amplifier was protection happy @ .35 with tones, and some music due to low voltage.
IMO.. one 1500d should be limited to 1 ohm nominal use in factory electrical systems.. for the sake of the car.. not the amp
now... to have fun with some juice..
1 amp, single 1000ca everstart maxx, 1 Eagle Picher 12a5000, factory alt
4 ohm nominal = 520 watts @ 88% efficiency (voltage fell from 14.3v, to 14.1v)
2 ohm nominal = 960 watts @ 84% efficiency (voltage fell from 14.3v, to 13.7v)
1 ohm nominal = 1635 watts @ 75% efficiency (voltage fell from 14.3v, to 12.8v)
.5 ohm nominal = 1890 watts @ 71% efficiency (voltage fell from 14.3v, to 12.8v)
.35 ohm nominal = 2245 watts @ 65% efficiency (voltage fell from 14.3v, to 12.8v)
amplifier did fine @ .35 with tones and music with the added battery
All of the impedences listed above was before rise.. and the wattage was with the rise. As it says"amplifier was protection happy @ .35 with tones, and some music due to low voltage."  it went into protect because of low voltage, not short circet. so according to there this. With the H/o alt and  possibly another battery besides my 1125 cca g31 battery, it will truly put 2245 watts.
BTW the TL was shipped today.
True...You can also feel your improvements ;D
yes but i can't hear the proven test 45% lose of hearing
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
They come from batterys plus... good battery so far.... it was better then anything else they had there.
G31 size(same size as the pc2150)  same configuration as the pc2150.. 1125cca for $75-85
so hopefully the Hifonics Colossus will be here by the between the 16-22.  so that well mean around 2800-3200 watts i hope..... so after that vids will be up with TL inplace
  • Who's Online   0 Members, 0 Anonymous, 1137 Guests (See full list)
