Need Help With My Setup
LoudNLow931
get cooling. hixm coil, and daily. your gonna need a bigger alternator, need to replace the batt upfront with the biggest one that will fit (powermaster, or kinetik) atleast one more big bat in back and your gonna need to do big 3 and at least 1 run of pos. 1 run of neg from the batt up front to the back in 1/0. just a warning. your probably not gonna be able to do the system the correct way and stay under your $2500 budget.
what if i went with like one 15 or one 18? my brother has 2 13w7's with 3 1000/1v2's and he didnt need to change the alternator..... and just added another batt and its fine... I donno.
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
Ok so im about to order my 15" BTL's. And i was just wondering what to get(like the options) Ohm? P Chamfer? cooling? HiXmCoil? Daily or SPL? Induct heat ring? Universal? Anyhelp with this would be great. Then in a couple days im ordering my Rockford Fosgate T40001bd. Also can anyone help me with where to get my wire and everything eles i need(I need to know what all to get) please. Also what does the big 3 mean? And is a bigger altanator need? im not gonna have it up all the way lol.
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
btw Joe, theres a little button on the bottom right of your post called Edit. use that instead of triple-quadruple posting :).
your gonna need an extra alternator and batteries as you will be pulling 4kw+ worth of power to the subs alone.
Kicker 2500.1's will be perfect, just get the Dual 1 coils, (1 2500.1 per btl). Dual 1 coils will allow you to wire a sub to 2 ohms, which is the lowest ohm load you can put on any Kicker amp w/o risking the amp being damage.
you WILL need to do the Big 3 under your hood (search for the Big 3 thread on here, its stickied in the electrical section). you WILL need to have at least 1 deep cycle battery in the trunk and one under the hood.
and you WILL need to get a High Output alternator of at least ~160amps.
subs will cost you about $500 fully loaded each, amps will be around 700-1000, wiring will be about $100-150, alternator will set you back about 150-300 depending on the power output and brand, and about $100-200 in batteries. *prices might be a bit inflated, just a guesstimate*
choose all the options and the Daily option if you want to have the loudest sub Fi has to offer, if not just make it stock (no options selected). Dont choose the SPL option ever unless you want to only play tones on it.
Knukonceptz wire is pretty good, i recommend them. Kicker wire and Rockford Fosgate wire are very good brands also.
The amps are going to be very power hungry so you need a good electrical system to help sustain decent voltage above 12v, anything under that and your getting into trouble.
Wow thats alot of stuff i need to do with the little amount of moneys i have. I think the stock alternator in a 98 deville pushes 200amps. If not t0 get a 200amp alternator it will be $250(http://cgi.ebay.com/ebaymotors/98-99-DEVILLE-ELDORADO-4-6L-200-AMP-ALTERNATOR_W0QQitemZ190102980273QQihZ009QQcategoryZ33573QQrdZ1QQssPageNameZWD1VQ
QcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247). You think if i get all the stuff needed and build my box the audio store will instal it all? The place is called Radio Active and its in Tullhoma,TN(if any1 has heard of it). Im hoping they would be able to im not to experianced on working on eletrical stuff and dont wanna mess something up. Never new it would be this hard lol with my old system i didnt have to do any of that lol. but of course that was just best buy kicker woofers and a 600watt amp lawlz. thanks for the help.
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
do you want your amp used or new?...and you can get your wiring at darvex.com heres the link.. http://www.darvex.com/miva/merchant.mvc?Sc...tegory_Code=CAW ...they got good things for almost at low prices...and you can type MEADE in the coupon section so you could get a discount.. http://www.sonicelectronix.com/item_7771_R...r+T40001bd.html heres on place you can buy the amp plus free shipping but i guess is a lil too expensive for you... heres a other amp but its only 3k watts... http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=14335 and free shipping too..but like i said its only 3k watts..i would say save up a lil bit more on money because your gonna need more stuff to power those !!BEAST!!...
Yeah im gonna get my subs first then my amp the the wiring. is this what i would need? http://www.darvex.com/miva/merchant.mvc?Sc...Product_Count=1 or this http://www.darvex.com/miva/merchant.mvc?Sc...Product_Count=1
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
that would work but your gonna need more power wires...specially to do your BIG "III" and for adding more batts...i would say this http://www.darvex.com/miva/merchant.mvc?Sc...Product_Count=1 ... plus maybe 3 or 4 of this fuse holders+the fuses http://www.darvex.com/miva/merchant.mvc?Sc...Product_Count=1 ....for your "BIG III",for the amp,batts..gota keep everything SAFE..and for your batts i would go with these ones.. http://www.darvex.com/miva/merchant.mvc?Sc...Product_Count=1 .... or these ones http://www.darvex.com/miva/merchant.mvc?Sc...tegory_Code=Kin ....
Lots of money i dont haz lol. What if i got 1 18' FI BTL and a T2000.... Would that cut the cost any? I really wanna do the 2 15's and the t4000. but im not a eletrition lol and i know ill mess something up.
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
then if you want 2 FI BTLS "15s" and a 4K ROCKFORD FOSGATE AMP..that covers it up...like i mean in the two BTL'S are gonna cost you like atleast $1,000...the amp $1,400+...that covers your bugget..$2,400...and your missing alot more too..WIRES,ALT,FUSES,BATTS,WOOD.if your gonna build your own box..i would say just stick with 1 BTL 15 or 18 and get a 2K watt ROCKFORD FOSGATE AMP..temporalry..how ever you spell that..lolz..preety much the 2k watt amp is overrated too i think..instead of 2k watts it gives you more..lets say 2,500 watts...if you set it up right...if i were you i will go with (1)BTL FULLY LOADED..2K watt amp...thats gonna save you money for your electrical...
  • Who's Online   2 Members, 0 Anonymous, 1416 Guests (See full list)
