Changing amps, These work perfectly I bought them brand new, The XA-1500d new out of the box looks like the heatsink mold wasnt cleaned and it has some marks on it. Thing is a beast!
PowerBass XA-1500d and XA-2150 Asking 300 for the 1500 and 235 for the 2150
SPECIFICATIONS:
• 4 ohm Power : 500W x 1
• 2 ohm Power : 1000W x 1
• 1 ohm Mono Power : 1500W x 1
• Strapped Power : 2500W
• Total Harmonic Distortion : <0.5%
• Frequency Response : 10Hz - 400Hz
• S/N Ratio : >90 dB/W/M
• Damping Factor : >200
• Input Sensitivity : 0.3 - 8.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 50Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 45Hz
• Dimensions : 14.17" x 10.51" x 2.56"
• Dimensions : 360mm x 267mm x 65mm
XA-1500d
SPECIFICATIONS:
• 4 ohm Power : 150W x 2
• 2 ohm Power : 230W x 2
• 4 ohm Mono Power : 4600W x 1
• Peak Power : 300W
• Total Harmonic Distortion : <0.02%
• Frequency Response : 10Hz - 30,000Hz
• S/N Ratio : >97 dB/W/M
• Low-Pass Crossover Freq : 40Hz - 400Hz
• Dimensions : 13.78" x 10.51" x 2.56"
• Dimensions : 350mm x 267mm x 65mm
XA-2150
This topic is now closed to further replies.
