Shinju Posted September 2, 2008 Report Share Posted September 2, 2008 Changing amps, These work perfectly I bought them brand new, The XA-1500d new out of the box looks like the heatsink mold wasnt cleaned and it has some marks on it. Thing is a beast! PowerBass XA-1500d and XA-2150 Asking 300 for the 1500 and 235 for the 2150 SPECIFICATIONS: • 4 ohm Power : 500W x 1 • 2 ohm Power : 1000W x 1 • 1 ohm Mono Power : 1500W x 1 • Strapped Power : 2500W • Total Harmonic Distortion : <0.5% • Frequency Response : 10Hz - 400Hz • S/N Ratio : >90 dB/W/M • Damping Factor : >200 • Input Sensitivity : 0.3 - 8.0 volts • Crossover Slope : 12 dB • High-Pass Crossover Freq : 50Hz - 250Hz • Variable Subwoofer EQ : 0/+18 dB • Subwoofer EQ Frequency : 45Hz • Dimensions : 14.17" x 10.51" x 2.56" • Dimensions : 360mm x 267mm x 65mm XA-1500d SPECIFICATIONS: • 4 ohm Power : 150W x 2 • 2 ohm Power : 230W x 2 • 4 ohm Mono Power : 4600W x 1 • Peak Power : 300W • Total Harmonic Distortion : <0.02% • Frequency Response : 10Hz - 30,000Hz • S/N Ratio : >97 dB/W/M • Damping Factor : >200 • Input Sensitivity : 0.3 - 8.0 volts • Crossover Slope : 12 dB • High-Pass Crossover Freq : 50Hz - 250Hz • Low-Pass Crossover Freq : 40Hz - 400Hz • Variable Subwoofer EQ : 0/+18 dB • Subwoofer EQ Frequency : 45Hz • Dimensions : 13.78" x 10.51" x 2.56" • Dimensions : 350mm x 267mm x 65mm XA-2150 Link to comment Share on other sites More sharing options...
