Gearstix Posted September 13, 2008 Report Posted September 13, 2008 I'm going to design a box for my two MTX Thunder 3000 8ohm 12's. I had been given a Pioneer home stereo by my cousin who replaced the 12s with the Thunder 3000s.. I will be using this box @ home. I don't really care how big it is, as long as it isn't asctronomical in size. I listen to rap and rock mostly. This is what I found in regards to the Thiele-Small (T/S) parameters.. found them in a listing on eBay, as MTXs site I could not access. Heres what I have entered into WinISD. Is this correct? I would like to make this box as simple as possible. Was thinking of using round ports, of PVC. 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
aznboi3644 Posted September 13, 2008 Report Posted September 13, 2008 if you followed the directions for entering parameters than it should be good. did you click "edit driver" or "new driver"
Gearstix Posted September 14, 2008 Author Report Posted September 14, 2008 if you followed the directions for entering parameters than it should be good.did you click "edit driver" or "new driver" New driver as it is not in the data base. I went and looked up the definitions of the T/S parameters, and this is how I guessed it would go.. Thats why I asked. Most of them were already listed like Sd and Xmax. 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
