avs20 Posted September 30, 2008 Author Report Share Posted September 30, 2008 Ok... inside word is this (although it's all unofficial of course, if your shit blows up)They have bench tested up to 20v () at which point they make a rediculous amount of power, but to run this you have to modify the overvoltage protection, and its for burps only. They will be OK to 18v but anything over that without modification and the protection will give you trouble. Hope this helps I can possibly get the bench-test results for all the voltages too, will see. Could you find out what is necessary to remove the overvoltage protection? Quote Link to comment Share on other sites More sharing options...
Boon Posted September 30, 2008 Report Share Posted September 30, 2008 I'll try, but remember that modifying the amp invalidates it for a lot of competitions... Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
avs20 Posted September 30, 2008 Author Report Share Posted September 30, 2008 I dont compete...this is a daily setup Quote Link to comment Share on other sites More sharing options...
