ohm is resistance. and ya. best way to find out what it is is look it up on the internet.
Bills
KwB
Team DC Audio Midwest captain
I'ma have a crack at this..... ha
You don't change your amp to 1 or 2 ohm, you change how you wire the subs. Ex. Parallel and series. Parallel lowers ohm loads by connecting + to + and - to -. Wiring in series raises the ohm load by wiring + to - and + to -.
Say you have dual 2 ohm sub. You wire in Parallel, you get a 1 ohm load. You wire the same sub in series you get a 4 ohm load. So you only change the subs total resistance. Not the amp itself.
~Team Bad Company Captain
"It is the mark of intelligence to be able to entertain a thought without accepting it."
by parallel u mean like bridged?? an if i bridge em its 1 ohm but if i do it normal it 2 ohms??
starting fresh, chrysler 300.. no subs amp nothin
I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click!
No, you "bridge" an amp. If it is a 2 channel amp, when you wire the two together, the is "bridging."
What are your sub? and ohm load per sub?
at the moment i have a jbl gto 14001 with 2 mtx 5500 10s bridged an i think there 2 ohms but im not sure
Well there is not bridging going on, that is a single channel amp. i'm guess by model number.
But at any rate, If they are single 2 ohm, then if you are running in parallel then your amp is seeing a 1 ohm load.
If they are wired in series then your amp is seeing a 4 ohm load.
you also change how much power is applied to the speakers. EX: having 2 12" subwoofers, each having a Single 2 Ohm voice coil on it. having 2 of them and wiring them in parallel would make it 1 ohm. connecting the 1 ohm load (the 2 speakers in parallel) to an amplifier, the speakers would get a total of 1000rms.
now thats not 1000rms to each speaker, its shared among them equally, so each speaker would get around 500rms.
if you wire 2 of the same speakers in series, you would get 4 ohms. now when you connect this 4 ohm load to the same amplifier, the speakers would each receive 125rms, or a total of 250rms. (125+125=250)
  • Who's Online   0 Members, 0 Anonymous, 2852 Guests (See full list)
