cartunez2004 Posted November 19, 2008 Report Posted November 19, 2008 ok so i have seen people put double dins in s10,jimmys, blazers need help on doing it. will it just fit it normally??? i no u would have to cut the bezel, any help and pics would be great thanks new toy 97 chevy s10 ext cab bagged 22s system (coming soon ) 4 soundstream t4-15s walled 2 concept 2410 mono amps REFS http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004 http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
Applejack Posted November 19, 2008 Report Posted November 19, 2008 somebody was selling a bezel on here somewhere that accomodated a double din if i remember correctly. ill try and find it. EDIT: This is what i was thinking of, i don't know if it will work for a double din though i was mistaken. http://www.stevemeadedesigns.com/board/ind...showtopic=21450 Midwest Car Audio is on facebook! http://www.facebook.com/pages/Midwest-Car-Audio-Association/101253286585630
cartunez2004 Posted November 19, 2008 Author Report Posted November 19, 2008 somebody was selling a bezel on here somewhere that accomodated a double din if i remember correctly. ill try and find it. EDIT: This is what i was thinking of, i don't know if it will work for a double din though i was mistaken. http://www.stevemeadedesigns.com/board/ind...showtopic=21450 ok thanks im pretty sure they fit in the dash u just have to modify the bezel but not sure new toy 97 chevy s10 ext cab bagged 22s system (coming soon ) 4 soundstream t4-15s walled 2 concept 2410 mono amps REFS http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004 http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
cartunez2004 Posted November 19, 2008 Author Report Posted November 19, 2008 somebody was selling a bezel on here somewhere that accomodated a double din if i remember correctly. ill try and find it. EDIT: This is what i was thinking of, i don't know if it will work for a double din though i was mistaken. http://www.stevemeadedesigns.com/board/ind...showtopic=21450 yea i seen that but no way im payin 500 for that bezel when i can modify it myself just tryin to figure out what i gotta do thanks new toy 97 chevy s10 ext cab bagged 22s system (coming soon ) 4 soundstream t4-15s walled 2 concept 2410 mono amps REFS http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004 http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
getonerd Posted January 13, 2009 Report Posted January 13, 2009 well u might need to find an bezel like this or a junker wit a rds radio because rds radios are double din im still looking for a kit to mount the radio so thats what i found out so far 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
01xtreme Posted January 14, 2009 Report Posted January 14, 2009 not 100% sure, but bezels out of 2002 and newer S10 have a double din opening, as they had the RDS radios that were double din. You will still have to make a mounting bracket, but the bezel with fit fine, and all the other openings for your AC, rear window wiper/hatch pop, and 4x4 panels will line up perfectly. the bezel pictured above is one of those with the factory double din. anything 1998-2001 will only have 1.5 din opening, so it would take some cutting, and body work to make it fit, and look good. You can usually find bezels for less than 100 bucks, plus whatever shipping will be. My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon...
getonerd Posted January 15, 2009 Report Posted January 15, 2009 i found this on eBay 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
01xtreme Posted January 16, 2009 Report Posted January 16, 2009 i found this on eBay That wont work with the 1.5 din dashes because the holes for the mounting screws are different. I believe the double din units only have 3, and the 1.5 have 4 My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon...
xtremez Posted January 23, 2009 Report Posted January 23, 2009 That wont work with the 1.5 din dashes because the holes for the mounting screws are different. I believe the double din units only have 3, and the 1.5 have 4 yeah mines a din 1/2 and i believe it has 4. i want to put a double din as well. went to a local shop..they were gona charge out the a$$ to do it.
Justin Posted January 23, 2009 Report Posted January 23, 2009 I have a 99 s10 blazer. I wanted the same thing so I had to cut a little out if the bezel then I ca glued the trim ring. Then I just finished molding it in once I was done. The I took the hu and it fit right in the opening of the dash. I had to cut just a little out of the top brace. Then I just positioned it to where erything lined up. And I havent had no problems. You will have to make a mounting bracket for the hu tho. 99 2dr Blazer Kenwood KVT-614 SounDigital SD16k 4 Fi BTL 18s 4 hertz high energy 6.5s comps 4 stock ad244 alts 6 g31s batts 8 runs 0ga
