alan412 Posted December 5, 2008 Report Share Posted December 5, 2008 one 15 inch Fi Bl. here are the specs. im planning on going with the dual 1 DUAL 1 | DUAL 2 Fs: 35.1 Hz | 34.5 Hz Re: 0.75 Ohms/coil | 1.5 Ohms/coil Qms: 6.23 | 6.34 Qes: .47 | .43 Qts: .44 | .40 Mms: 232g | 240g Cms: 0.089mm/N | 0.089mm/N Sd: 810cm^2 | 810cm^2 Vas: 81.6 l | 81.6 l Spl: 90.6dB 1W/1m | 90.7dB 1W/1m Bl: 12.8 N/A | 19.0 N/A Xmax: 21mm Rms: 1000W * Sealed box: N/A cuft Ported box: 2.8-4 cuft @ 30-37Hz Sub OD: 15.625” Cut ID: 14.125” Mounting depth: 8.250” Displacement: 0.18cuft (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h Link to comment Share on other sites More sharing options...
Guest Posted December 5, 2008 Report Share Posted December 5, 2008 a D1 will only let you wire at .5ohms and 2 ohms if you didnt already know that Link to comment Share on other sites More sharing options...
alan412 Posted December 5, 2008 Author Report Share Posted December 5, 2008 a D1 will only let you wire at .5ohms and 2 ohms if you didnt already know that what about the D2? (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h Link to comment Share on other sites More sharing options...
raytard Posted December 5, 2008 Report Share Posted December 5, 2008 vehicle planned power space limitations spl? music? daily? Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
alan412 Posted December 5, 2008 Author Report Share Posted December 5, 2008 vehicleplanned power space limitations spl? music? daily? 2001 honda civic ex sedan Rockford Fosgate T1000 1BD amp Width 40 inches, Height 23 inches, Length 30 inches Rap, daily (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h Link to comment Share on other sites More sharing options...
raytard Posted December 5, 2008 Report Share Posted December 5, 2008 well, heres what im getting( 3/4 in mdf), outside dimensions of 17high, 28 wide, 24 deep, a port using a vertical wall that ends up being 15.5h x 3w inches x 25inches long in there i included ~.6cuft of bracing, so u can use what you like internally, maybe a top to bottom, front to back to one side of the sub (move the sub as far oppisite the port as you can and brace next to it, and one left to right, maybe with allthread, so that the port and such is braced. not needed if you have access to 1in thick mdf, i can re-do sizes slightly to compensate just so u can see what i mean as far as configuration, first one on google images that was right...idk who those people are with that, its about a 32hz tuning, about 12.25 sqinport/cube, 3.8cu/ft (what fi says is right in their optimum tuning) port i guess is a little small for spl, but should belt out great sq and be very musical, and with a 15inch bl @ 1000wattsrms, u shouldnt have problems. if you dont plan on bracing, or are using allthread throughout, let me know, basically take 1in off the width for every .2cu/ft of bracing you dont want to use to keep tuning/size consistant, leaving it too big will drop tuning and effeciency unfortunately, but still be fine, just not optimum. Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
alan412 Posted December 5, 2008 Author Report Share Posted December 5, 2008 so you're building the same enclosure? is that correct or did i misinterpret the first sentence you typed? (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h Link to comment Share on other sites More sharing options...
