Need Help Designing An Enclosure For...
alan412
one 15 inch Fi Bl. here are the specs. im planning on going with the dual 1
DUAL 1 | DUAL 2
Fs: 35.1 Hz | 34.5 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 6.23 | 6.34
Qes: .47 | .43
Qts: .44 | .40
Mms: 232g | 240g
Cms: 0.089mm/N | 0.089mm/N
Sd: 810cm^2 | 810cm^2
Vas: 81.6 l | 81.6 l
Spl: 90.6dB 1W/1m | 90.7dB 1W/1m
Bl: 12.8 N/A | 19.0 N/A
Xmax: 21mm
Rms: 1000W *
Sealed box: N/A cuft
Ported box: 2.8-4 cuft @ 30-37Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.250”
Displacement: 0.18cuft
(Headunit) Pioneer DEH-P3100UB
(Speakers) Phoenix Gold RSd 65cs
(4 Channel) Alpine MRP-F300
(Subs) 2 15" Audioque SDC2.5
(Box) 7.27 cubic feet tuned to 31 Hz
(Mono Amplifier) Elemental Designs Nine.1
(Wiring) 1/0 Knukonceptz KLMX
(Batteries) 2 C&D Tech 75 a/h
a D1 will only let you wire at .5ohms and 2 ohms if you didnt already know that
what about the D2?
vehicle
planned power
space limitations
spl? music? daily?
2001 honda civic ex sedan
Rockford Fosgate T1000 1BD amp
Width 40 inches, Height 23 inches, Length 30 inches
Rap, daily
well, heres what im getting( 3/4 in mdf), outside dimensions of 17high, 28 wide, 24 deep, a port using a vertical wall that ends up being 15.5h x 3w inches x 25inches long
in there i included ~.6cuft of bracing, so u can use what you like internally, maybe a top to bottom, front to back to one side of the sub (move the sub as far oppisite the port as you can and brace next to it, and one left to right, maybe with allthread, so that the port and such is braced. not needed if you have access to 1in thick mdf, i can re-do sizes slightly to compensate
just so u can see what i mean as far as configuration, first one on google images that was right...idk who those people are
with that, its about a 32hz tuning, about 12.25 sqinport/cube, 3.8cu/ft (what fi says is right in their optimum tuning) port i guess is a little small for spl, but should belt out great sq and be very musical, and with a 15inch bl @ 1000wattsrms, u shouldnt have problems.
if you dont plan on bracing, or are using allthread throughout, let me know, basically take 1in off the width for every .2cu/ft of bracing you dont want to use to keep tuning/size consistant, leaving it too big will drop tuning and effeciency unfortunately, but still be fine, just not optimum.
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
so you're building the same enclosure? is that correct or did i misinterpret the first sentence you typed?
  • Who's Online   0 Members, 0 Anonymous, 1021 Guests (See full list)
