EpicenterDesigns Posted January 31, 2007 Report Posted January 31, 2007 to see what it may look like, I cut the center out of the panel and dropped the monitor down in there. Needs a little more trimming, but it will fit very nice. Not too big, not too small. Keep the vents for that cool AC. And it is all touchscreen operated. Coolness. Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
EpicenterDesigns Posted January 31, 2007 Author Report Posted January 31, 2007 I made filler pieces and ground off extra parts GM felt the panels needed. Shaved the 4x4 delete panel at the top by the center vents and the airbag cutoff switch in the center near the factory radio housing. Also shaved off the vent adjusters and built up the center of the 2 middle vents. Ended up shaving the body line and the mounting screw hole above the gauges also. Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
EpicenterDesigns Posted January 31, 2007 Author Report Posted January 31, 2007 this is tacked in with CA glue Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
EpicenterDesigns Posted January 31, 2007 Author Report Posted January 31, 2007 Liquid plastic applied Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
EpicenterDesigns Posted January 31, 2007 Author Report Posted January 31, 2007 Sanded Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
EpicenterDesigns Posted January 31, 2007 Author Report Posted January 31, 2007 Thin plastic paste to fill in bigger holes Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
EpicenterDesigns Posted January 31, 2007 Author Report Posted January 31, 2007 Not a good pic, the other ones washed out with the flash. But it has been body filled and smoothed with 220. Filler primer will flow onto it and I will wet sand it smooth. That is all. Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
EpicenterDesigns Posted January 31, 2007 Author Report Posted January 31, 2007 Wet sanded the primer down after a guide coat was applied. Not a great pic, but it is smooth. Right after this is when I decided to shave that screw hole. So i did that, reprimed it and assembled. Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
EpicenterDesigns Posted January 31, 2007 Author Report Posted January 31, 2007 Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
EpicenterDesigns Posted January 31, 2007 Author Report Posted January 31, 2007 Inspector #43 had to come check it out. Building The Best.....Repairing The Rest The bitter after-taste of a poor quality job will last far longer than the sweetness of that cheap price!
