Zooyork2Sincity Posted January 20, 2009 Report Posted January 20, 2009 I have a question on my front end staging. Below I will put the info on my current setup as well. I made an inpatient mistake and bumped my system without fully setting it up. I knew I was doing wrong but did not think I would blow my tweeters. I had a set of Seas H1397-04 27TAFNC/D Compact neodymium magnet tweeters. To be honest I am unsure of what the mids are in my doors I swore we put RS125-4 5" Reference Series but then actually believe they are ScanSpeak 15W/4531G Revelator 5.5" unless I pull off my door panels I won’t know for sure. I blew my tweeters because I was inpatient and didn’t connect resistors and caps to them and their connected directly to the mids that are connected to the Xtant 603. I needed to buy new tweeters but then saw a set of Rockford Fosgate T1T 1.1" Hard Anodized Aluminum Inverted Dome Tweeters with crossover and figured this would be good they come with crossovers I saw a full set with mids deal I couldn’t pass up new ROCKFORD FOSGATE T162S 6.5" COMPONENT SPEAKERS $120.00 shipped so I purchased them and now when I received them the magnets are smaller they’re way lighter then the SEAS and unsure if my impulsive decision was a good one. Here are the Specs of my set up please let me know if the SEAS are the better choice or are the Rockford a great decision. I listen to hard hitting bass music of course and R&B and still like SQ as well I need help I am so indecisive… My setup currently: 2006 Nissan Titan XE Crew Cab (4Door) Kenwood KVT 915-DVD, 15” Re XXX at 1200 watts, Components/ Center channel: Seas Audio & “ Possibly Dayton Reference For the front end Xtant – 603X: Number of Channels 3 Watts per Channel 4 Ohm 2 x 75 + 1 x 150 Watts per Channel 2 Ohm 2 x 150 + 1 x 300 Front Channels bridged mono at 4 Ohms 1 x 300 on the sub I am running the Xtant 1001X Here are the specs on the tweeters SEAS Here are the Rockfords Description Value Configuration 2-Way Component System Midrange Diameter 6.5" Midrange Depth 2.7" Tweeter Diameter 1.1" Tweeter Depth n/a Frequency Response 60Hz - 22kHz Power Handling 100 Watts RMS 200 Watts Max Crossover Low-Pass (LP) 12dB High-Pass (HP): 24dB Sensitivity 89dB @ 1 watt/1 meter Grilles Included Yes Mounting Hardware Yes PLEASE HELP 1999 - 2Door Chevy Tahoe Kenwood KVT 915-DVD II 15” RE XXX (Fi Recone) II Components/ Center channel: Seas Audio, ScanSpea&k Dayton Reference II Amp’s: Xtant – 603 & 1001 Chipped & Tuned II Misc. Team PowerMaster Batt Cell, Xstatic 2000 Batcap, Street wires Zero Oxygen RCA Cables, 0 Gauge through out II Security Clifford Intelliguard 770
