what you wanna do is if possible clamp your pieces together with the glue and while the glue is setting up pre-drill your holes for you screws then screw in your screws and take off your clamps and move on to the next piece...
countersink is this little drill bit and it's not a necessity but if you were going to round off all your corners on the outside you'd have to do it unless you plan on wrapping the box in carpet or just leaving it bare wood
1997 Dodge Ram Van 2500
Big III addition with 1/0 awg wiring all throughout
Lightning Audio Strike S4.1000.1D
Jenson XA2250
2 - 12" Mtx Jackhammers JH55
3ft cubed box sealed under the rear bench seat
Pioneer DEH-P6000UB head unit
MB Quart FWA 160 components up front
personally i would just paint the port and vinyl the outside.. i wouldn't put vinyl inside the port if that is what your talking about doing.
Jenson XA2250
o i c
i will do that then........would i be good to round off all corners and what internal bracing??? i want a loud box that hits good lows that is strong and that will work in competitions......i am soon after i get the money gettin another lvl 4
2004 Chevy Tahoe LT........... THINKING
o i c
as far as internal bracing goes i'm pretty sure the double baffle would be plenty but like i said add 45's to the corners and i think you'll be good.. it'll be a strong box no doubt and it's tuned between 32-33hz so it'll get pretty low just add pictures when you build it! i would like to see my creation someday
Jenson XA2250
cool deal and back to your sub up port back i'd just go with the drawing.. either way i think it'll sound about the same.. there might be a different but sub back and port back is already drawn and it'd be the easiest to build so i'd go with that
Jenson XA2250
here are some boxes i've built before
i'm a fan of t-lines as you can see and in that video i was using a single 12
if i find the links of the full builds i'll post them up here.
http://www.stevemeadedesigns.com/board/ind...mp;#entry497473
http://www.stevemeadedesigns.com/board/ind...showtopic=36780
http://www.stevemeadedesigns.com/board/ind...03&hl=tline
Edited by amazinblazin10
Jenson XA2250
