Box Help
I have two 08 kicker l5 12"s in the kicker box wired to two ohms off a hifonics 1608d. I would like to make this setup louder and lower by building a box and need a little help with dimensions and port design. It is going in a jeep cherokee and I have 40"x22"x19" high to work with and was thinking around 32hz for the port?. So if anyone could point me in the right right direction?
Thanks
Edited by charokee
Sundown SAZ-3000
2 12" T3 DVC1ohm subs
58hz peak cabin frequency no deadner yet
box tuned to 38hz
BIG 3 upgrade
yamaha patio speakers rear fill
Alpine 9833 deck
PPI FRX-456 Crossover
PPI PAR-245 Preamp/EQ
PPI DEQ-30 Band EQ fronts
PPI tweets in kick panel
PPI 2-way's in kicks for now
0/GA 1 run front to back
Memphis 4 channel running rear speakers 75 X 4 only 2 channels used for now
Planet Audio 4 channel 75 X 4 running front speakers
146.7 db usaci drivers door open
163.3 db port challenge mic in port
2012 4door silverado
The port is maybe a little bit on the large side but otherwise that should work very well :)
Consider making the port 4" wide and adjusting the length to get similar tuning - ~33hz
ya I'll give that a try does it matter having the port on the one side with two subs? also should I put the subs up and port to the tailgate and how much room between the tailgate and port should there be?
thanks
  • Who's Online   1 Member, 0 Anonymous, 1666 Guests (See full list)
