Please Help Meca Class What Class Will I Be In
i can use 100-125 fuse,, but i only have a 200. and need to re order new ones.
my amp has 2-70 amp fuses, its a 1606-d hifonics
1-10" woofer
will in be in as1-as2-as3 ???
i wanna be in the best class i cant go lower then a 100 amp fuse on my power wire..
please help..
{(Total Amperage of In-line Fusing X 10) + Woofer Cone Surface Area} = Pressure Class #
Please consult Division Rules for complete definitions.
SPL (Sound Pressure League ) Format
Fuse Requirements Listed
Permitted: AGU, AUE, ANE, ATC, ANL, or Mini-ANL (also known as MIDI); 32 volts maximum
AS - Amateur Street - Basic, daily use systems. Beginners & those who have not been champions. Owns equipment. No Pro’s.
AS1 0 - 550 -- 1 Fuse
AS2 551 - 1000 -- 2 Fuses
AS3 1001 - 2000 -- 3 Fuses
S - Street - Intended for daily driven vehicles. Competitors show who can do the most with the least.
S4 2001 - 4000 -- 4 Fuses
S5 4001+ -- Fuses Not Required
Edited by BassBoy69
144+ DB'S OUT OF A CONVERTIBLE
12" Funky Pup Subwoofer (The worlds most powerful subwoofer)
6" Aero Ported Box
Hifonics - Bxi2010-D
Pioneer Deck
RD Audio - Front Speaker
Rockford Fosgate - Rear Speakers
KnuKonceptz - 0 Gauge Wire
KnuKonceptz SS Karma - 10 Gauge Sub Wire
KnuKonceptz - Krystal Kable Rca
Big 3 - Upgrade - 0 Gauge
Kinetik - Hc1800 Battery
anyone know.. i just wanna fall in the right class, and not get my ass handed to me..
so if i swap out fuses or somthing i could do better in a lower class.. idk..
6" Aero Ported Box
Pioneer Deck
hmmm you have two fuses on your amp so i think those they will be the ones counted for your classing and that will put you in AS3, you do not want to run as3 one of my teammates will be doing over a 150 in that class, try gettin fuses for your amp and see how low you can go
im not 100% sure if the will count ur amp fuses or not tho
yeah my amp has 2=70'sm and i can do min 100, on my power wire.. on 1 -10"
im just seeing where ill fall into i don wanna findout ill be with someone with 2-15".. you know.. but we are limited so idk.
6" Aero Ported Box
Pioneer Deck
There's no WAY they can be talking about number of fuses on the amp chassis itself, can they?
4 x 15A fuses would be no where near 2 x 60A fuses for example.
I'm pretty sure they're talking about your power wire.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
hmm i jus remember i think the only time they use the fuses on the amp is if there is no fuse on the power wire, so yeah try burping with the lowest fuse in there just work your way down
haha yeah my teammate will be with 1 18
ill can only play music, no real tone burps,..
ill just buy a few different fuses,.. and see what i can do, it will be my fist time and i just wanted to do decent,
6" Aero Ported Box
Pioneer Deck
well i know for sure ill blow the cheap 60amp glass fuses,
i now like i said only have a 200 anl,
so ill try and order 100 and up fuses, and see at what point do i stop blowing them..
if anyone has any more tips to help me, please givem,
6" Aero Ported Box
Pioneer Deck
what is the deal i was told i need to have a fuse right next to my amp ?
when my fuse is at the front on the battery ?
6" Aero Ported Box
Pioneer Deck
  • Who's Online   1 Member, 0 Anonymous, 995 Guests (See full list)
