Memphis Mojo T4k
Dtprez08
I have 2008 memphis t4k and it was only able to go to the 1 ohm. but Ive been hearin that ther .5 ohm stable jw if any one has ran then that low b4 i kno at my shop the owner was sayn he kno bout the new 09 models to be able to do .25 load and like 6krms out the box . so if any one knows about the 08 models let me kno im tryin to get .5 out of my Dc 18s
Are we talking about burp? I seen it personally that these amps will do it,, and make some big #'s at 16v,.... but i wouldn't try it for music unless you had 8 batteries and even then you are pushing the shit out of that amp. Not recommended!!!!!
Save your money and get a bigger amp if that's the case.... it will save you money and lots of Headaches in the end.....
2007 1st West Coast Regional Champ S/Max 157.3Db
2008 1st West Coast Regional Champ S/Max 158.8Db
2009 160db is my Goal!!!
Stetsom's West Coast Rep
Team Stetsom
these amps are good at 1ohm.. i havent seen them lower then then 1ohm so i dunno..i know the more volts the better the sound on these amp tho. i got a small memphis mono and the guy from memphis told me the 1100watt is rated at that on 12volt and at 14 its almost 1600 watts..never tryed it tho..
1996 Ford Taurus
2 yellow tops
1/0 gauge wire
800amp batcap
4gauge to amp
1 MCD Memphis 1100
3 kicker L7 10s (4)ohm droped
Pioneer 6*8s
jenson 200watt amp
Memphis rates all there amps at 14.4 unless its changed recently
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
i kno on my box it was 12.4 to 14.4 and for bust it can handle alittle more.. my volts stay around 13 and i dunno why my batcap sends a 14.4V out to the amp i think i got a bad draw or something..
1996 Ford Taurus
2 yellow tops
1/0 gauge wire
800amp batcap
4gauge to amp
1 MCD Memphis 1100
Pioneer 6*8s
jenson 200watt amp
  • Who's Online   0 Members, 0 Anonymous, 714 Guests (See full list)
