Got this amp about 2 years ago when it was brand new. Paid around $300 for the thing. Had it installed to 2 kicker comp 12s for about a month, and took it out to replace everything with my JL setup. As soon as I took it out, it went straight back into its original packaging where it has been stored in my closet ever since. Comes with original everything. Box, manual, even the faceplace which is not pictured. I have it sitting in my room, just forgot to snap a picture of it. I can if someone really wants me to.
This amp is virtually flawless. Specs are listed below...
# 165 watts RMS x 2 at 4 ohms
# 254 watts RMS x 2 at 2 ohms
# 505 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
# stereo or bridged mono output
# CEA-2006 compliant
# Tri-way capable (Tri-Way crossover required)
# requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
# AMS Amplifier Management System (-15 to 15 dB bass level control, Q factor control, bass/treble frequency control)
# variable 50-200 Hz filters (24 dB/octave low-pass, 12 dB/octave high-pass)
# switchable subsonic filter (0/15 Hz, 24 dB/octave)
# LED status display (AMS settings, voltage, current, temperature, fan speed, and protection status)
# cooling fan
# 15-3/16"W x 2-7/16"H x 10-7/16"D (11-1/8"D with RCA cables connected)
Looking to get $75 plus shipping for it. These are still going for $150-190 new and mine is practically brand new.
This topic is now closed to further replies.
