Kenwood - Protect Mode
can anyone help me i got a kenwood deck and it's stays in protect mode it just started doin it today, i pressed reset the first time and it worked but it did it again and now it just says protect flashing does anyone know whats wrong with it?
Team Deadly Hertz
I just had a guy come in today with that same problem at our shop. His problem was a half blown speaker that metered out at 1 ohm. Once I disconnected the speaker all was good in kenwood land. Just use a DMM to check your speaker impedance and check for a straight ground on all the leads sometimes a grounding out speaker can cause this problem as well. As far as voltage goes if you power reads below 11 or above 16 volts you'll shut down a kenwood deck too. I hope this helps you out man.
The Shoe Maker without shoes!
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
