barely used, I have a single 2 ohm Fi IB3 18" and the opti loves 1 ohm and .5 ohm, 2 ohm not working for me
$250 plus shipping.
http://i248.photobucket.com/albums/gg178/kryptonitewhite/mix/DSC_0003
http://www.importtuner.com/reviews/p...er/system.html
Quote:
TEST RESULTS OUTPUT POWER @ 1%THD, 1KHZ, 14.4VOLTS
MONO @ 4OHMS 770 WATTS
MONO @ 2OHMS 1118 WATTS
MONO @ 1OHM 1687 WATTS
MONO @ 0.5OHM 1962 WATTS
OUTPUT POWER @ 1%THD, 1KHZ, 12.5VOLTS
MONO @ 4OHMS 673 WATTS
MONO @ 2OHMS 988 WATTS
MONO @ 1OHM 1406 WATTS
MONO @ 0.5OHM 1635 WATTS
DISTORTION AT RATED POWER, 1KHZ, 14.4VOLTS
0.14% @ IMPEDANCE
INPUT SENSITIVITY 250MV TO 8VOLTS
FREQUENCY RESPONSE ( + 1DB) 15HZ -130KHZ
S/N RATIO (A WEIGHTED, BELOW CLIPPING, MIN GAIN) > 83DB
SLEW RATE 6.5V/MSEC
DAMPING FACTOR @ 100HZ, 4 OHMS 105
IDLE CURRENT 2.1AMPS
MAXIMUM CURRENT CONSUMPTION,
UNCLIPPED 117AMPS @ 1152WATTS
EFFICIENCY AT 1/3RD POWER
LOWEST IMPEDANCE 79%
EFFICIENCY AT FULL POWER, 1%THD,
LOWEST IMPEDANCE 85%
CROSSOVER SLOPE 24DB/OCTAVE
CROSSOVER RANGE, LOWPASS 48HZ - 155HZ
SUBSONIC SLOPE 24DB/OCTAVE SUBSONIC RANGE,
LOWPASS 14HZ - 56HZ
LOW FREQUENCY BOOST +19DB @ 43HZ
DIMENSIONS 19 1/8"L X 10"W X 2.5"H
IB3 22"
This topic is now closed to further replies.
