brewer_brewer Posted March 11, 2009 Report Posted March 11, 2009 Impact screwdriver. Set that bitch on there and bash it with a hammer, couple of good taps and those screws will be begging to come out yep. thats what i had to use on mine. Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
ISO Posted March 11, 2009 Report Posted March 11, 2009 Impact screwdriver. Set that bitch on there and bash it with a hammer, couple of good taps and those screws will be begging to come out I agree x3 and if they use the samesize philips I'm used too then you might need to move up to a number 3 philips from a number 2 philips bit to get the best bite and to keep from stipping out the heads. When I put the screws back in I like to put just a little bit of lock tite on them to secure them because once the spider is glued its glued. You got me. Just a dot per screw not much incase you do another recone latter on. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
