Posted (edited)
Ok so on my neon that has air bags on it, the rims are a 40 offset,
and in the back once drops rubs,..
the inner wheel lip rubs a bar of the suspension once i adjust my air ride, so iv had to use wheel spacers in the back, i dont like spacers i like having hub centric rims on,.. and having them safe..
i found some new rims, that are a 38 offset.. so how will that be.. more rub? or less.. or do i need to get ahigher then 40 offset ?
and i have to be carful now to have a rim that sicks out because when i go to trun shape the out part of the tires may rub inside the front fenders...
Edited by BassBoy69
144+ DB'S OUT OF A CONVERTIBLE
12" Funky Pup Subwoofer (The worlds most powerful subwoofer)
6" Aero Ported Box
Hifonics - Bxi2010-D
Pioneer Deck
RD Audio - Front Speaker
Rockford Fosgate - Rear Speakers
KnuKonceptz - 0 Gauge Wire
KnuKonceptz SS Karma - 10 Gauge Sub Wire
KnuKonceptz - Krystal Kable Rca
Big 3 - Upgrade - 0 Gauge
Kinetik - Hc1800 Battery
anyone know?
6" Aero Ported Box
Pioneer Deck
lower offset means it'll be closer to the fender. from a +40 to a +38 means you'll be 2mm closer to the fender. measure the clearance you need and order wheels with a proper offset to ensure you aren't rubbing. rubbing on the fender is an easy fix, get em rolled or stretch your tires and you should be fine.
well Im using them on my neon so ill have no inner lip, how ever if they stock out enough the front may touch somthing inside the fender, not the fender its self..
my real question is, if i want a wheel to no rub on the inner wheel lip do i need a higher offset or lower.. cause my 40 off sets lip on the inside rub my bars of my suspension,.. do i need higher or a lower number.
6" Aero Ported Box
Pioneer Deck
Posted (edited)
by saying fender, it could be inner or outer. doesnt help here.
the lower the number, the further out the wheel will stick.
ok so ima look for somthing under a 40 then cause 40s are not working. thanks guys.
Edited by BassBoy69
6" Aero Ported Box
Pioneer Deck
i should have specified outer fender but i'm pretty sure bassboy understood. you need a lower offset wheel. don't go nuts though. too low and tucking will get tricky.
understood, thanks. I just want to get a wheel that fits right for once,
so ima do some research to find a nice rim..
6" Aero Ported Box
Pioneer Deck
