Working Condition 10/10...Cosmetics 10/10...Perfect for a sigle 12 or 2-10's.
Asking:
$60 Shipped
$40 Pickup (Manteca Hayward, Stockton, Lodi Areas)
75 watts RMS x 2 at 4 ohms
150 watts RMS x 2 at 2 ohms
300 watts RMS x 1 bridged output at 4 ohms
900 watts MAX X 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-Way capable
requires a 10-gauge wiring kit with a 30-amp fuse — wiring and hardware not included with amplifier
variable high- and low-pass crossovers (50-250 Hz at 12 dB/octave)
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
variable Punch Bass (0-18 dB boost at 45 Hz)
speaker- and preamp-level inputs
11-1/8"W x 2-7/16"H x 9-7/8"D
Has Remote Bass Knob But No Wire Included... :8)
This topic is now closed to further replies.
