ok well March 29th will be my first competition and i want to make the most out of it!
well I will be attending the midwest spl event at mach 1 audio in washington missouri... big prob is sometime my amp goes into protect
now it hasnt yet on push that nigga push that hoe which is what i will be usin for the 3 min kaos run so................
i have the batt in back grounded to metal basically under this plastic peace... should i find a bolt and sand it and matel down very good until shiny and use that??
thanks
-Ryan
2004 Chevy Tahoe LT........... THINKING
thanks
-Ryan
Judging by your name id assume you have an explorer? Run the battery ground through the floor and bolt it to the frame. That will help a lot.
You can see the hole in the floorboard right above the cleaned spot where my battery ground is bolted too.
Edited by 95_100
Don't use an existing bolt, take some steel wool and get where you are grounding to be bare metal, no paint. Before you drill, make sure you don't put a bolt into the gas tank, spare tire, fuel lines, or brake lines.
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
Take the carpet up, and use the steel wool to get bare metal. DO NOT USE AN EXISTING BOLT. Use a self tapping screw, and I would use a screw with a Phillips and also a bolt pattern on it. Ya dig?
Car
1996 Sable LS
My Build
Truck
Truck Build
oh i c thanks man!!
should i wrap wire in electrical tape so it doesnt get cut??
No prob, and what do you mean get cut?
Car
1996 Sable LS
My Build
Truck
Truck Build
like get cut on the metal but i will just use a grommett lol
where do i pull up carpet?? does this mean i gotta take my system out??
I put up 2 pics for ya. Best thing is to put a rubber grommet around the hole. You can pick them up at any hardware store, just pick one up that the 1/0 or whatever your wire size will fit through, look at the hole size for it and drill a hole that big and you should be set.
were r the pics?? i want to c this
