It doesn't look like 5" away from the back of the box. Creyc is right. The actual length of your port(using the 2nd of the 2 sketches) is 29.25" long.
oh wait, let me see.
I know its 5 inches high from the top, i thought it was 5 inches to the back from the top of the port..
Hold on.
Okay. That pic of the port inside the box i posted is not the updated one. I cut off about an inch I thought, but yeah that would only leave 4.5". Looked right with a tape measurer. So IDK I guess I'm just not too sure. I might just have to redo the entire port... IDK how tho, Id have to rip the tops off...
Nvm, I can't do that, I have to make due with the port how it is now, and wiat till later to rebuild the box.
Is it still possible to tell the tuning of it?
Edited by rumproast789
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
bump?
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
bump?
bump, I am going to carpet this if the tuning is pretty close to what it was supposed to be, if not, I'm going to rebuild it later and not carpet it...
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
get some sine sweeps and do some and try and listen to where it peaks idk? you can probably estimate it's tuning by that..
1997 Dodge Ram Van 2500
Big III addition with 1/0 awg wiring all throughout
Lightning Audio Strike S4.1000.1D
Jenson XA2250
2 - 12" Mtx Jackhammers JH55
3ft cubed box sealed under the rear bench seat
Pioneer DEH-P6000UB head unit
MB Quart FWA 160 components up front
Ya i'd probably not be too good with that, but if it comes down to it I'll try. I'm sure someone can figure it out, I'm hoping that is lol.
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
so you made your port smaller and longer...both of which drop tuning
but i think you did somethign wrong somewhere, 7cubic feet net, 20.5x5 port, 21 long, gives approx 38hz tuning
Team DC
It was supposed to be 22x5, 20.5 inches long = 33hz. isn't it different for my type of port to calculate tuning tho?
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
