Im wondering how many packed watts/subs I can fit into an S-10 custom build Im starting on.
My thoughts were to get 12,000 watts into'er! ( where would I place/hide the batteries, amplifiers, ect ect...)
Heres a brief overview on whats gonna take place with the S-10 project....
- Lowered with a complete bodydrop, basically having the rockers sitting on the ground.
- truck frame boxed in, leaded smooth, then chromed. Parts painted metalic orange. ( like the frame color in my avatar)
- installing a 572 chevy bigbloc engine. This shrinks the cab because the firewall will be pushed in.
- also the bodydrop will shrink the height of the cab space too...
- air system,Co2 tanks polished ect.....The truck will basically have an unlimited budget, & will be on/off the trailer for shows. LOL probly wont be drivin it too much!
Do you think having a 12,000 watt bass system is wayyy out of possibility? I'd like my amps to be rockford fasgate & FI woofers.
look at 00dime00 build. the lil red truck that turned green. i had 2 t1 15's in a reg cab before.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
I am starting on a 98' sdime build in a few weeks. The plans are as follows:
Pioneer AVHP6000DVD head unit
Kicker ZX2500.1
Kicker Solo X 12 (dual 4)
Kicker ZX850.4
Kicker SS 6.5" mids
2 pair kicker kx 2 way 6.5" coax
250 amp alt
optima yellow top
Kinetik HC800
Big 3 Upgrade
This is all going in an extended sdime
Jared Nixon  A.K.A. Jsmoke
My Car Stereo Website: 3rd Coast Customs
My Fishing Website: BigLake411.com
Add me as a friend: Myspace
Download: Check out my Audio Calculations Spreadsheet (Microsoft Excel)
ATTENTION ALL SMD MEMBERS: Do not under any circumstance buy anything from Chassistech! They do not stand behind their products & their customer service is horrible. They do not actually manufacture lowering springs, they drop ship them from Spring Tech. Chasistech.com also does business as Airbagit.com, Streetridepro.com & Truckinsuspension.com. They are all the same company! Do not trust these bastards! Their products are cheap & more often than not, you don't get what you actually order in the first place! YOU HAVE BEEN WARNED!
To handle 12kW on music you'll need a few beastly subs. You said Fi interests you, so assuming you ran BTLs you would want between 4 and 6 woofers to take the power. Even if you ran 12's you'll want at least 2 cubes per sub, plus port, giving you a box around 10 cubes plus port. I'm not sure if you can fit this in an extended cab wall or not.
If it's a show truck you may want to consider a simple sealed box, which should save you some airspace but might rule out the BTLs and require more lower power handling subs.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
Would you be willing to do a blow through?
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
00sdime00's s10....
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
Matt W.
1996 Thunderbird LX Sport 4.6
new system soon...still deciding on what to get.
