Saltine Posted March 18, 2009 Report Posted March 18, 2009 ok, had a totalled navigator at work and the owner couldnt get his radio out b/c he didnt have one to replace the pioneer with. so after he gave the vehicle up i went and snatched the radio. it was working in the navigator i bring it home wanted to hook it up to a battery and see if there was any cd inside before i go make a quick hustle selling it. red and yellow to positive black to negative wont power on, wire makes the contact spark letting me know i have good contact just no power on the radio, and the fuse behind the wore harness on the back of the radio is fine to. im no amature to car audio but this one has me. radio is a deh-p680mp
tacomabanga1986 Posted March 20, 2009 Report Posted March 20, 2009 i got one of those, hmm, make sure the faceplate is connected good? does faceplate even move? and did u try hittin the reset button? here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
Saltine Posted March 21, 2009 Author Report Posted March 21, 2009 i forgot about this thread, but its sorta fixed the face would not move its shut completly, we took the radio apart and jumped the motor out for the face to rotate down. when you give it power, it turned on and it closed up. really really weird, anyway we found that the ribbon going from the face panel to the radio itself has 2 really small pinholes you can only see by putting a flashlight behind it. turns out the ribbon cable is $50 and a common problem. im not going to fix it, at least not right now. if you rotate the face down, and power it up now it plays perfect, just cant put the face up or it turns off when that cable shifts.
raytard Posted March 21, 2009 Report Posted March 21, 2009 ive seen like 3 or 4 radios wtih those faces and that same problem great radio for a few years, then the cable wears and it shorts and does that kinda funky stuff Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
