so for example the receiver my friend demoed the sub on didn't have any special outputs for subs (they were all the same). would this mean, basically, that i could run mah shit on any old receiver without much risk?
If you can run the sub directly off the reciever there will be a speaker wire output designated for the subwoofer. and you should have no problem running it like that
If you plug the 4 ohm sub in the 8 ohm speaker output, over heating problems can come up
What i am saying though; If the reciever allows you to directly hook up the sub to the reciever, as in a channel for sub use only, it will usually(check the manual for specs)have a lower impedence rating like 4 ohms. then it will be ok
yes the .1 is the subwoofer channel
2.0 is just 2 speakers without a subwoofer
2.1 is 2 speakers with a subwoofer
4.1 is 4 speaks with a sub
and so on
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
  • Who's Online   0 Members, 0 Anonymous, 2227 Guests (See full list)
