How To Set Up The Amp
Derek16
put the gain at or around where you think 2v would be, if it goes from .5-12, (left to right, and knowing amps .5 is prob at the 7 oclock position and 12 is around 5oclock, use about 9 oclock)
does the amp pop the subs when it cuts? is a thermal light on? are any lights on?
otherwise take it back and complain, probably shouldve done that first, most shops dont like it when customers who admittedly dont know gain from gauge start messing with stuff.
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
there is a green light on saying its on i believe. but i mean the sub literally just turned off. completley stopped working. the speakers still worked just fine, just the subs stopped.
the amp goes from .2 volts to 5 volts. do you still recomend 2 volts?
Edited by Derek16
  • Who's Online   0 Members, 0 Anonymous, 1160 Guests (See full list)
