So...Im not going back to stock, ive blown that twice in 2 years now. So im thinking posi or a locking diff. Im not too knowledgeable when it comes to matters under the hood or involving the drivetrain. Which would be a better choice. I know Eaton is supposed to be a good name. Any and all help is appreciated. Also, where would be a good place to look that has fast reliable shipping. This is my DD and im kinda hunting for a job at the moment so i need it back in action ASAP.
Thanks in advance for your help.
woman..cant live with em...cant shoot em...guess were all fucked
You might be a Redneck if you use your leftover gutters for a speaker box port...
YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
How did it go 2 times in 2 years? Do you beat on the truck? Who installed it? Is yours a 4x4?
The 7.625 in rear is the same as the 7.5 rears of other models. You have to be very careful with putting a posi in one as these rears are not the greatest. If yours is not a 4x4 you can swap out the whole rear for a 4x4 unit and they have a locking diff standard for 2000 I believe.
The other option and probably the best one is get a custom built rear, probably a 12 bolt or a ford 9 inch rear.
ya its the 4x4...I wont lie, im not the most gentle to her, but i dont beat the piss outta it either.
also, this is my DD, i dont tow, and the system isnt that big yet. Someday i imagine it will make the blazer noticeably slower off the line...What should my ratio be 3.23, 3.42, 3.73?
Seeing as you have a 4x4 you need to closely match the front gear ratio with the rear. If the rear is too high, it can cause problems.
You will have to go to a junk yard and see if they can give you a beefier unit from a different truck. I think you can put a Ford 8.8 from an Explorer I believe with a little modification. Best bet is a junk yard or mechanic. You are going to be spending at least $600 most likely either way.
I know a few mechanics. My one buddy who is a mechanic reccomended going with a detroit locker limited slip, i just dont quite know what ring and pinion i would need to get for it.
  • Who's Online   1 Member, 0 Anonymous, 2156 Guests (See full list)
