lethal916 Posted April 26, 2009 Report Posted April 26, 2009 i need some help on my system, i get engine noise when i power up my subwoofer amp. when i just got my mids and highs amp on theres no noise. any help? Quote
Guest KyleCannon Posted April 26, 2009 Report Posted April 26, 2009 So there is only engine noise on the subs but not the mids? If thats the case, check the subwoofer ground and make sure its grounded well. Quote
lethal916 Posted April 26, 2009 Author Report Posted April 26, 2009 (edited) So there is only engine noise on the subs but not the mids? If thats the case, check the subwoofer ground and make sure its grounded well. thanks for the help, i tried changing the grounds already, is it okay for all the amps to share one ground? and when i only have the power wire is on the amp without the ground on there i hear the noise. any help? Edited April 26, 2009 by lethal916 Quote
lethal916 Posted April 26, 2009 Author Report Posted April 26, 2009 Huh? when i only have the power wire on the sub amp it makes the noise. Quote
Guest KyleCannon Posted April 26, 2009 Report Posted April 26, 2009 Then stick the ground in it too? Quote
lethal916 Posted April 26, 2009 Author Report Posted April 26, 2009 Then stick the ground in it too? im saying when the ground is out there is still noise and with the ground in place there is still the noise. Quote
Guest KyleCannon Posted April 26, 2009 Report Posted April 26, 2009 Try moving the ground to another location if you're using it on the chassis. Take a DMM and measure the resistance from the wire to the chassis as well. Quote
lethal916 Posted April 26, 2009 Author Report Posted April 26, 2009 thanks i will have someone who knows how to use one of those to check it tomarrow. thanks Quote
