Ok I am currently getting a Sundown 1200d.
Right now my truck only has a 70 or a 90amp alternator on it which is probably going to be a joke with that amp being it is fused for 150amp.
So could I get away with a 120 or 140?
Breaking in a sub is like breaking in your girl before you pound her....
IMO u are fine with ur stock alt. Just have enough battery to back up that particular amp and charge them periodically. If you upgrade later down the road look not getting a better alt.
Random vids of the Avalanche My link
Team Bass-Hz
Ok cool.
Right now I have a duralast under the hood, brand new. 1000cranking amps but not sure on the other specs.
Maybe just a rear batt?
Any ways I can get more voltage easy?
Also I can get a 120alt for like $200ish or just a battery.
Hmmm. I will try and see but I know before even with just my Jenshit 300w amp and the Alpine 350w (total fused to 65amps) I believe I was having voltage issues because when I turned it up and it hit some of the harder notes it would cut out. Not sure if that was voltage probs or if that was due to my subs on the amp.
Anyways I know I had that going on and that is why I asked. I did have a 5yr+ old battery in it at that time but I just put in a Duralast gold battery (1000CA)
Not sure TBH. I will take a look tomorrow. I will probably pick up a 120amp alternator and then a decent dry cell battery for the back when I get the money. I was also running 1 run of 8awg to both amps with a splitter running 8 awg to the rear which didn't help any either.
Well I found out I can get a Powermaster 140amp alternator for right at $200 which is a 1 wire setup? Also thinking of a MLA module.
Think I would be good to go then.....
  • Who's Online   0 Members, 0 Anonymous, 605 Guests (See full list)
